View Full Version : Bizhub 600
jej
03-04-2009, 01:47 AM
Will not feed from any cassette, but will feed from the bypass. M1 drive motor runs good, did load test. On prcb board, cn 203 6a only get 5 vdc, should be 24. Get 24 on two other connectors on the board, so it is not the power source. When I do the load test for the clutches, I do not hear them engage. I felt some of the feed clutches, they were not hot. Tried a different prcb board, same problem. Anyone out there seen this??
jrsbmw
03-04-2009, 02:39 PM
Yes I have, it's sitting in our shop right now! :cool:
Gleq
03-05-2009, 10:16 PM
have you also checked the user settings on cassette eligibility? it can be off
jrsbmw
03-06-2009, 04:44 PM
The M1 motor was bad, killed the PRCB, wasn't getting 24 volts. Got a new board from Minolta, the board was bad, got a second board from Minolta and the new PRCB board fixed the problem.
