View Full Version : Bizhub C250: disable chips
21043
03-06-2009, 09:22 PM
Hello!
Can toner or drum chips be disabled from service menu in Bizhub C250?
Thank you very much!
No.. you have to change the chips, it can not be done from the service menu.
cboucher
03-06-2009, 10:28 PM
No but they can be reset with a chip resetter device. I'm pretty sure a company that sells those advertises on this site. Probably really expensive, though.
SEnder
09-03-2013, 11:12 AM
Hello!
1. Call the Service Mode to the screen.
2. Press the following keys in this order.
Stop → 0→ Clear
3. Enhanced Security menu will appear.
11.3.5 IU Life Stop Setting
Functions • To select whether or not to stop a print cycle when the IU reaches its service life
Use • Use to select not to stop the print cycle when the IU reaches its service life.
Setting/
Procedure
The default setting is Stop.
“Stop” No Stop
