View Full Version : samsung scx 6320 f
jlvelez
03-10-2009, 01:05 AM
need help w/a Samsung SCX 6320 F with open heat error code.
I think this could be the heat rod or heat lamp, can anyone help me?
xcopy
03-10-2009, 01:37 AM
Remove Fuser and measure across heat lamp with multi meter.
tseto
04-27-2009, 11:25 PM
The Scx 6320/6322 does not use a heat lamp. like the old xerox 412 the upper fuser roller has an embedded heating element bonded to the inside surface of the aluminum roller and a contact on each end. The fuser bearing crumples under use and the contacts at the end no longer works. check the fiber bearing at each end of the upper fuser roller. if crumpled, a new fuser is needed to be ordered. the bearing is not available from Samsung.
jlvelez
04-28-2009, 12:20 AM
tks for your inf. Do you know of a site or a company i can buy parts for the samsung?:)
cmcomputer
06-29-2009, 01:50 PM
ACMco 717-397-4264
