indesign/account track/C450
  • lanierboy
    • 149
    hello all,
    i have a bizzare problem on a windows XP machine that has had SP3 applied.
    the customer uses account track on thier printer and now if they produce a new document in indesign it authenticates and prints ok but if they try to print an old indesign document the machine drops the job as not authenticated
    the customer has patched InDesign with all available patches for CS2 and are still getting the same problem. Have also tried using full authentication rather than account track and it is still the same, even if you try to log on as a public user.
    The problem is definitely at the computer end because if you select the authentication through printer preferences, come out and then go back in without printing the option is unchecked again. So the driver appears to lose the setting even though it has been applied.
    anyone had this before??
  • kmcopier
    PSP
    • Oct 2008
    • 183
    Capture the job on the machine side and check the file ultraedit what is your driver version? what is the fimware off the machine?
    • lanierboy
      • 149
      hi
      firmware is version 3.05 driver is 3.01.
      when you say capture file, could you explain further what you mean.
      cheers
