minolta di 620 err code c-040
  • cosmin_mocanu
    • Dec 2008
    • 71
    I know that the code meens, ialready changed 2 fan's, but the macine still cames intoo this error. Does anyone have any ideea about how to fix this???
    P.S. soryy for the bad english, but i hope that you recieved the point of my problem.
  • Luther
    • May 2006
    • 682
    Is the code C0040? or C0400? C0040 is the fan under the transport section below the transport belts,(between the t/s corona and the fuser) C0400 is the exposure lamp,hope this helps
    • cosmin_mocanu
      • Dec 2008
      • 71
      it's c-0040. That is odd is the if i chenge the fan the copier works for a period of time and after that it's coming back
      • Luther
        • May 2006
        • 682
        Are you replacing the fans with new ones or out of an old machine? check ,clean or remove the ozone filters
        • cristian
          • 179
          Re: minolta di 620 err code c-040
          Salut Cosmin,
          Cum ai rezolvat-o cu 0040?
          Am aceeasi problema cu 2 masini.
          Culmea e ca am trecut ventilatorul pe bypass, si imi da acelasi cod, cand mi-e lumea mai draga....Deci nu e ventilatorul, e altceva.
          Cristi Enciu
          Piatra Neamt
          0720 011964
