ZeusGT
03-14-2009, 04:45 AM
Hey guys, I recently purchased a BizHub C250 with the works (print,scan and fax) and it has a very low meter (9432).
The fax board is installed, but when you hit the fax button, nothing happens. I went into the TechRep mode (periphial settings) and made sure that the fax feature was "set" and it wasn't. When I set the feature I was able to go into the fax feature window, but couldn't do anything else... no dial tone.. nothing.
When I turned the machine off and then back on, I got the CB000 code and the machine shut down.
I took another "known good working" fax board off of another C250 and installed it into the other machine with the same results.
What am I missing? It's ashame to let this machine go just because the fax doesn't work..
Can anybody help me? Are there any other features/switches that need to be turned on as well? Are there any intializations that I needed to do when I set the fax?
The board was installed when I purchased the machine, but the periphial settings tab showed the fax was "unset". Thanks for all your help.
