View Full Version : konica minolta bizhub c351
javier4065
03-19-2009, 04:55 AM
hello,Can I use toner konica minolta bizhub 352 to konica minolta c351.I want to say if it is the same. Because the customer bought toner forcf 900 and the copier began to have problems of quality copy.
Give a big congratulations from me and us in here to your costumer. Now i suggest that u charge him extra coz u will have to replace all IU's where he put non orginal toner and every toner tube that comes from toner to IU and u will have to dismantle whole back of copier to get to the tubes.
As for toner u can try and maybe fail. Its on u to try. Even tho i dont understand why to buy toner for c352 since its same price and capacity as for c351?
dogsbody
03-19-2009, 10:13 AM
just use genuine konicaminolta C351 toner for a C351, the C352 is a completly different machine. The one thing I fight for in my office is use model specific GENUINE toner for colour machines. You are just asking to spend more time and aggravation at this site, so unless it is a high class strip club with the machine by the bar, just make them by the right toner.
Cheers.
AjitN
03-22-2009, 06:47 AM
Dear All
C352 gives better gloss than C351, but needs some adjustments.
Regards
javier4065
03-23-2009, 12:22 AM
thanks friends,but what are these adjustments that I must do to obtain a good copy.
so far i use compatible toner as the same. i also see the 'ingredients' is the same even IU developer also... :)
mitchl
03-23-2009, 04:57 PM
Isn't the 352 a laser based machine and the 351 a LED machine? Try to dig up the fuser specs and have a look at the temps, it should be a tell tale sign of a different flash point.
Bizwork
03-23-2009, 05:05 PM
Just to second the last couple of replies is, no you cannot use C351 on a C352 because the toner is completly different...
fitsy.13
03-23-2009, 06:08 PM
no you cant the 351 is a mf22 machine and the 352 is a mf 30 machine to different toners
