View Full Version : C-4705 Error Code
konicasux
03-19-2009, 06:37 PM
I keep having this error code appear. Any ideas on how to prevent this? It comes up about every 20,000 prints. It is on a Konica C6500. Any suggestions are much appreciated.
tervel12
03-19-2009, 07:16 PM
Update your firmware to the latest level. Version 50 is the most current.
konicasux
03-19-2009, 08:08 PM
Thanks for your help!
Si@danwood
03-20-2009, 07:41 AM
Check the image memory control board version/Part no. If it ends in 15 then this most likely will be the cause and will need to be replaced.This is found stamped on 1 corner of the circuit pwb and the last 2 digits are normally on a sticker .Hope this helps Si
konicasux
03-20-2009, 01:28 PM
I will check that. I really appreciate the help.
