View Full Version : Bizhub C351
Vesigoth
03-21-2009, 08:46 PM
Unable to receive faxes. Transmitting ok. The fax board is sensing a a fax comming in I can hear the handshake but then I get a error message " job completed inproperly check the log. R25". Any ideas would be helpful. Thanks.:)
pepper38_cnd
03-21-2009, 11:01 PM
That is an ECM error there may be noise on the line, are they sharing the line with DSL? If so install a filter. Try turning off ECM
Vesigoth
03-25-2009, 01:59 AM
Thanks for your help Pepper38. I'll check that out.
masterteknicion
03-25-2009, 03:24 AM
Make sure the marketing area for the fax is set to US.
Vesigoth
03-25-2009, 06:26 AM
Thanks mastertecnicion. It's set to US. Good guess though. I've run into that problem more than once too.:)
dudley
03-26-2009, 01:25 AM
make sure that your not on VOIP. really screws up the ECM
Vesigoth
03-26-2009, 10:59 PM
After all that I found the HDD was unset:mad: Thanks for the help guys.
