Konica Minolta C6500 Pro - Black patterns and Yellow clouds
  • alopezv
    • May 2025
    Hi,
    I have two quality problems with me bizhubbiz hubMore... C6500 pro.
    The first one are bands in black color, I see that repeat about 7.5" or 190 mm, I am not sure if repeat between this distance but is not more visible.
    The second problem is like yellow clouds see over the color print. I not all prints are in the same place and not the same size are very irregular.
    Thanks for info that help me to solve this.
  • sbillis
    • Nov 2008
    • 95
    Originally posted by alopezv
    Hi,
    can you upload samples?
    can you be more specific about your problem with bands in black color? are thin in portrait or landscape?
    yellow clouds maybe from developer.
    show us some samples
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Hi,
      The black bands may be from a drum blade having flipped.
      The yellow could be anything from developer,toner,or damp paper.
      • simon
        yellow clouds = a colour the rip cant produce if there random on each print
        print test pattern 53
        and set
        magenta to 130 and the others to 0
        the go to cyan and set that to 130 a nd the others to 0 do this on all 4 colours ,you probally wont see anything in the yellow
        see if the bands appaer on one colour or all
        • alopezv
          and set
          Simon, thanks for this clear process i tell you about results.
          • Herrmann
            • Jan 2006
            • 792
            As a Rule of Thumb for Repeater Marks, you can take as follows:
            Failed mechanical part.
            Approx 188mm pitch: Damage on the drum surface.
            Approx 251mm pitch: Damage on the fusing belt
            Approx 53mm pitch: Developer conveyance failure of developing sleeve.
            Approx 95mm pitch: Soiled second transfer roller
            Just interchange your bk drum with another, per example the magenta drum and see, if the error migrate to magenta.
            As for the yellow clouds, try the method, simon mentioned before.
            good luck
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
