Keyvee
03-24-2009, 02:53 AM
We've started using PullPrint on C253 & C451 MFDs and are getting this message each time we print.
It appears immediately after hitting the Start button to begin a print out.
The exact message is:
The printer is printing the following document
[Document Name]
Press OK to continue!
Apart from being an extra button press when printing, the screen locks the interface until the “ok” button is pressed - that is, you cannot log out if the ok screen is active. This becomes a security risk because documents can be reprinted if the user does not log out.
Has anyone found a way of turning this screen off or getting around it? It seems completely superfluous.
Thanks,
David
[Document Name]
Thanks,
David
