Minolta Di620 code C-0F24
  • redline485
    Hi,
    This is my first post. I work in a small print shop doing bulk mailings, some design, and some digital print. I am having an issue with my minolta 620. It is throwing a C-0F24 code. Im pretty sure its a toner code for one of the sensors. Anybody know where or how to replace or clean it. I was told it was somewhere under the drum. Any help would be appreciated.
    Thanks,
    Rick
  • tony_218
    • Oct 2007
    • 24
    soloo es el sensor aidc que se encuentra debajo del cilindro por donde recicla el toner solo lo limpias y listo
    • redline485
      Sorry i dont speak spanish. Translation?
      • Kmdurrin
        Copy/Print/Network Tech
        • Dec 2008
        • 132
        Faulty AIDC sensor in the cleaning section, below the drum
        Parts: Its what your copier craves!
        • GUILHERME
          • Mar 2008
          • 18
          Cleaning the AIDC sensor under the drum.
          good luck.
          Guilherme.
          • fixthecopier
            ALIEN OVERLORD
            • 4714
            It is on you if you want to pull the drum, be careful. I have had that sensor blocked by paper. If you plan to service the machine yourself, get a manual and it will show you where the sensor is and how to get to it. Good Luck!
