View Full Version : Konia - Minolta 8050 problem
captain1976
03-26-2009, 10:50 PM
I have a 8050 that says "operating please wait" This will not go away and the machine will run for hours like that. Any suggestions?
kmcopier
03-27-2009, 10:07 AM
Check your fuser unit there is maybe an paper stuck on the between the web and upper.
captain1976
03-27-2009, 11:14 AM
I will check it out and let you know.
Captain
captain1976
03-27-2009, 12:50 PM
Fuser looks fine. I even removed the web and everything appears normal
Luther
03-27-2009, 02:03 PM
Are you sure thats the exact message? or is it "copying please wait" or "adjusting please wait"
captain1976
03-27-2009, 02:37 PM
Hello,
Yes, it says "Please Wait" Adjusting and it will not go away. I can get it to print data sheets from the "36" mode but thats it
Luther
03-27-2009, 02:49 PM
Thats usually DMAX adjusting but it usually happens when the machine has been off for more the 6 hours,or every 1000 pages .or even if the humidity has changed at least 30%,sorry thats all i have for you.how long have you let it sit with that message ?
captain1976
03-27-2009, 02:57 PM
Hi Luther,
I got this machine last week and when I tested it out, it read the same thing. Then I turned it off and back on again and it said to replace the yellow toner. I did that and got it to make a few copies but then after turning it on again it will run for hours if I let it and still says its adjusting. There has got to be a specific reason it will not go out of that mode and the manual say nothing.
Luther
03-27-2009, 03:03 PM
Have you checked the other toners?
captain1976
03-27-2009, 03:11 PM
Yes,
The other toners are good but since I have new ones in stock I will replace them all and see it it does any good.
random
03-27-2009, 09:13 PM
This may be a red herring but on the c6500 if DIPSW 11-1 is set to 1 the error codes are ignored and in a fault situation the machine will do this. Perhaps you should check your handbook for a similar dip-sw.
kmcopier
03-27-2009, 09:55 PM
Start the machine up in 3-6 mode and make some test
