View Full Version : di3510 abort code 0x00dc0652
tarzak911
03-31-2009, 01:15 PM
:rolleyes: pls help me...what am i looking at ....
173545
03-31-2009, 02:15 PM
Scanner device control system failure
0x00dc0000to 0x00dfffff
MFB3 Board, Scanner Home Position Sensor. BCR board
tech51
03-31-2009, 07:16 PM
Its usually caused by the optics lock, see solution below. I know solution is for BZ250/350 but its effectively the same product.
Description
DF-605, abort code 0X00dc0652 when scanning.
Solution
PROBABLE CAUSES:
1.Scanner is in the locked position.
Access the scanner locking mechanism on the upper left side of the main body. Ensure that the locking switch arrow is pointing to the unlocked setting.
Please refer to steps 8 and 9 on page 4 of the bizhub 200/250/350 Installation Guide for an illustration.
2. Power Supply failure.
Check the Power Supply Unit (PU1) at connector PJ5PU1. The voltages should read as follows:
PIN # DC VOLTAGE
1 3.3
3
3 5
7 24
9 12
Note : If these voltages do notmatch the above readings,replace the Power Supply unit (p/n 4040 6201 01).
3.Open 24V DCfuse (F222) on the BCRS due to M12 (Scanner) harness pinched by the right cover (p/n 4040-1505-01).
As a temporary countermeasure, change routing of the harness for theScanner motor (p/n 4551 2013 01). Please see the attached file.
Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
Hope this helps :):):)
tarzak911
04-01-2009, 10:33 AM
thank from cape town...
i tried bcrs and it worked....
