View Full Version : Toner chip resetting
ZeusGT
04-04-2009, 05:20 AM
Is there a chip resetting tool for the C250/252 bizhub toner cartridges.
I ask because I have several Imagistics CM2520 out in the field and while the toner units are different only in the front cover and pin, but the powder is the same. I was wanting to take the Imagistics front covers off w/chip and put them on the Minolta but the chip counts the life of the toner and I would need to reset that if it's possible.
Any ideas. Thanks
Claudio
04-04-2009, 06:01 AM
I've never used their chip resetters, but I bookmarked this site in case I want to try it.
KonicaMinolta Chip Resetting (http://www.geocities.com/pepper38_cnd/IU_Chips.html)
also:
This is the place for all your Knonica Minolta Print Controller Fiery Needs (http://www.myprintcontroler.bravehost.com/IUResetting.html)
ni311
04-04-2009, 02:04 PM
The brick like resetter from the sites above doesn't work for C250/C252 series.
Mine neither :)
alexxcopier
04-04-2009, 04:56 PM
a side of subject, but chip related. Need a chip for pagepro 5650 with standard capacity /10-11k/ i found a few chips, but for pp4650 and high capacity
also any tip for resetting ??
thanks
pepper38_cnd
04-04-2009, 07:46 PM
ZeusGT have you tried just changing the toner cover and putting the chip from the new toner on, Some of the KonicaMinolta and Imagistics toner chips are the same just the cartridges are keyed differently. And no the C250 IU programmer doesn't program chips to be toner chips at least I have not had any luck doing it.
ZeusGT
04-05-2009, 10:59 PM
No, I haven't tried to do that being that I thought that the Minolta wouldn't reconize the Imagistics chip. I do need to try that though.
That is pretty much what I did with the older models though.. I would just clip the extra tab or modify it so that it would work with the Minolta. I'll give that a try.
pepper38_cnd
04-06-2009, 01:41 AM
Try it if you do need a chip resetter email me info@iuresets.com
shazza
03-25-2011, 02:49 PM
Hi ,
A friend has an OKi c5650. It is saying yellow drum low 0 %. He has ordered and chaned drum & toner complete twice!! Any idead hos to reset or what to do next?
Thanks,
Shazza
ni311
03-26-2011, 10:50 AM
Send me and email at office@chipreset.eu
