View Full Version : Color configuration C451
Zilviux
04-06-2009, 03:31 PM
Hello I want to know how to adjust color + density
+ for best results on KonicaMinolta C451? for example now photos is too dark and dark blue color is violete. I try to adjust density in administrator mode but only help a little bit for blue and if i put simulation profile the photo darkness good but it's less brigth.
For example is possible to get colours like on xerox ducucolor 5252? :confused:
8050
04-06-2009, 09:59 PM
You mention simulation profile. Your C451 has a IC409 Fiery on it? If that is the case start from scratch. Set your Fiery back to factory default. Ensure that your engine color is good through gradation adjust. Do you have a densitometer or spectrophotometer (ES1000)? Also what kind of paper are you using? Is it regular 20lb bond or 24+ lb color paper?
Zilviux
04-07-2009, 08:27 AM
No there is no fiery attached, just stock bult-in controller.... :(
wwandrei
04-07-2009, 10:47 AM
As far as i know if you don`t have fiery you can`t do much. You can try calibrating the copier from service mode but that doesn`t means you can make profiles and stuff like this ... use your software for this whatever you use ... colre or photoshop...
