C6500 red color problume
  • muhammad.imran
    • Jul 2008
    • 13
    hi
    dear all
    i am realy in trouble i have problume with colors spacialy red its print orangesh. i tried every thing gamma adjustmeny,gamma offset, contone,
    calibration,but there is no effect i hope u guys can help me to come out from this prob.
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Try the printer gamma offset adjustment, the manual way. I bet the automatic adjustment has put in too much yellow.
    • muhammad.imran
      • Jul 2008
      • 13
      red color
      dear
      thanks to reply but i hav been done this adjustment i reduse the yellow value even -50 and i increase magenta value and i checked it with diffrent adjustment values but still i foraway to perduce a red color and machine is still new 30 thousand print only
      • Setright
        FSS / SPM
        • Nov 2008
        • 247
        Okay, you need to think about replacing the gamma sensor. (It's part of the rail that also holds the colour registration sensors.)
        Try doing a full calibration, with the ColorCal including the scanner, OR by using a spectrometer.
        Then look at the graphs for each colour. If the lines flatten out toward max density, the gamma sensor is defective.
        • HORSE
          • Mar 2008
          • 186
          Yes check the colour registration assy. This contains the Gamma sensor and the 2 colour registration sensors.
          If the assy has an 'M' stamped on it with black ink this is the modified type....if the assy has a pink spot label then it has the old type Gamma Sensor and you will hav to replace it.
          modified part A03UR79800
          Laughing......
          • totoro
            • 568
            I agree, if your red is orange and your blue is purple then do as Setright and HORSE suggest.
            Totoro
            • 21043
              • 63
              hello!
              try to increase humidity in room.
              for example, "tunr on" electric teapot with opened top cover and let water to boil out (about 1 liter), then wait 5 minutes and try to print red colour.
              it realy helps with C500 pro and CF5001.
              • HORSE
                • Mar 2008
                • 186
                Originally posted by 21043
                hello!
                I agree get the customer to boil the kettle for a nice cup of coffee while you change the gamma sensor....
                Laughing......
                • muhammad.imran
                  • Jul 2008
                  • 13
                  RED COLOR
                  HI
                  guys thanks for ur reply i took gamma sensor, and registeration sensor assembly from 6501 i checked it with 6500 and i calibrate autocal but same color. humudity is already enough. one thing i noticed when run gamma sensor adjustment (auto) the cyan and magenta DC bais value only 240,238and yellow , black is 480,520
                  • 21043
                    • 63
                    already enough - how much?
                    humidity has to be not lower 40% - from my experience.
                    • copier skills
                      c6500
                      I had the same problem. I calibrated using the es1000 and the colors came right in.
                      • noklasony
                        • 18
                        hi guys
                        i hav same problumes and i hav done all thing that u people discused .
                        i also increase the AC devloping bais(under process fine adjustment)
                        i already replaced HV board,and registeration assembly M type
                        but dears i still have same prob if people need more information please ask .
                        • noklasony
                          • 18
                          red color
                          hi dear
                          i calibrate the engine and fiery also but problume still there .
                          one thing i noticed red color of test print 1 withh 255 yellow,and 255 magenta is also orangesh. i did all adjustment gamma,gamma offset,dot1, contone ,every thing i replaced HV board. so now can any one help me
                          • muhammad.imran
                            • Jul 2008
                            • 13
                            red color
                            hi guys
                            this is me again after pause but still i hav prob. i did every thing that u people told me. i orderd to koncaminolta new M type gamma sensor assembly i replaced it and i run all adjustment gain but prob still there and i already mentioned machine internal test print red color also orangesh
                            sooooooooooo what i can do now can any one tell me pls
                            • Bizhub
                              • 147
                              Originally posted by muhammad.imran
                              HI
                              Firstly ensure that the machine is correctly setup and all drums devs etc are in good condition, then Calibrate with a densitometer and check the outputs. Konica-Minolta have admitted to me that red's can be problematic on c500 and c6500's
