View Full Version : km-c2525e
when printing to this one from word or excel it works fine, but when my customer sends photos or a pdf to the machine it only wants to print the first page nothing else. ideas appreciated. thanks t
cboucher
04-09-2009, 12:37 AM
Try checking the "Print as image" box. I think it may under "Properties" in the Adobe print dialogue, don't remember exactly.
tmaged
04-09-2009, 02:01 AM
CBOUCHER is correct. It's under the advanced tab at the bottom when you hit print. It's an Adobe issue. You could install the PDF direct print utility.
blackcat4866
04-09-2009, 02:17 AM
It's after the Advanced button on the front of the print driver. Unfortunately it cannot be set as a default, so Print As Image must be selected each time a pdf is printed.
skinnypuppy
04-10-2009, 07:08 PM
Download and install KX driver if you haven't already. Once installed go to properties/device settings. and click on the PDL button change the setting to PCL5
aodtech
04-10-2009, 10:50 PM
Try going to Device Settings, PDL, make sure KPDL is highlighted, click Settings, make sure the box for "Allow data passthrough" is unchecked. This has solved many printing issues, especially with Adobe.
