View Full Version : C6500 code c3201
noklasony
04-12-2009, 12:50 PM
hi guys
any can help me regaurding 3201 code i alreaddy change fusing drive motor and exit sensor . this code appear moslty when customer use thick media and its not permanent its appear ofter few copies and just with ON /OFF machine get ready
dogsbody
04-12-2009, 01:56 PM
I couldn't find C3201 but have had C3102 codes before. If this is the case try replacing the Fixing Drive Gear M (A03U809311).
Cheers.
noklasony
04-12-2009, 05:07 PM
thanks 4 reply yeah its 3102 and mentioned gear i hav changed but still that problume is there
hosman80
04-13-2009, 01:53 AM
there are 3 gears/M that need to be replaced and their shaft cleaned, also check your fusing limiter.
HORSE
04-13-2009, 02:33 PM
hosman is correct there are 3 white gears within the gearbox section that have a oneway-clutch, these gears leak oil and best to replace them and clean the shafts.
Good tip is to roughen the shafts with a bit of wet & dry.
totoro
04-13-2009, 03:29 PM
3 fixing drive gears A03U 8093 11
1 fixing limiter 65AA 5365 1
1 fixing drive shaft A03U 7258 00
noklasony
04-13-2009, 06:33 PM
thanks to all guys
your tips realy useful and my machine is good now
thanks again
