View Full Version : km_1820/1500_pwb Error Diagram
jewen25
04-16-2009, 07:18 AM
help guys..its there a Error Diagram of Main PWB? pls help me...
HPLEXKYOPT
05-04-2009, 11:34 AM
G'day mate,
Try this site
Feedroller (http://www.feedroller.com/Store/kyocera_mita.php)
jewen25
05-06-2009, 11:52 AM
tnx for the reply bro. but need a diagram or a manual that where to fix the error of PWB not to need to replace new one
aodtech
05-08-2009, 10:16 PM
You mean something like this?
jewen25
05-11-2009, 05:12 AM
thanks for the diagram,but you have a other that indicate wheres the error?
aodtech
05-15-2009, 11:15 PM
Not quite sure what you mean by that. Shoot me a PM and I'll send you the Service Manual.
jewen25
05-27-2009, 10:30 AM
i mean a diagram that indicate wheres the error occur? or alternative solution to fix his error, i have SM but not indicate if it can fix?
kyoceradude
05-27-2009, 11:27 AM
Okaaaaayyyyy. What error are you getting?????? What code????? What message are you getting that is telling you that you have a problem???? What, what what. Nobody can answer your question unless you tell us what error. Sending info will not and has not helped you because we do not know what error you mean. Come on spit it out.
This is like a customer saying my copier dosen't work.
digital copier resources
05-27-2009, 01:28 PM
Are you looking for an x0003 error means replace resistor 232 type map?
If so then get out a meter or scope and troubleshoot the circuit using your electronics skills. No manual gives you component level replacement for erros that I know of. I used to troubleshoot boards to component level for Pitney Bowes way way back but we had to figure it out and build a boad test fizture and the like.
Good luck
jewen25
05-29-2009, 11:29 AM
i mean a diagram for any error contain in diagram? like error CF2? it can fix?
