View Full Version : Konica C6500 code C-2832
boxster964
04-23-2009, 04:37 AM
I had 2 codes a C-6708 code and later a C-2832.
I reseated the all boards ip, oacb, IF and prcb.
The C6708 code went away.
Bad news is a second code showed up it was C-2832
I replaced prcb and flashed the firmware V41
no change the hv sensor and pba replaced.
still no change if you try the auto gamma adjustment it fails.
any ideas ?
kmcopytech
04-23-2009, 05:57 AM
C-2832 Magenta Adj
Enter: Utility>Machinc Adm>System setting>Expert Adj>Process Adj>
Toner Quantity / Exposure
select standard(-2)>OK
HORSE
04-24-2009, 12:43 AM
any ideas ?
for the C-2832 try swapping the M drum around with another colour and see if code changes. Could be a dodgy drum.
boxster964
05-06-2009, 01:36 PM
The drums were replaced with the new style for blade flip problem. The fix was the IPB dont know why but it fixed the problem.
thanks for the help
