samsung scx 4720f "document jam"
  • ash_572
    • Oct 2008
    • 523
    customer says that they fed pages through the document feeder to fax and the machine came up with this document jam message. there is no paper watsoever however i think its a sensor that has come out of place. im not very familier with samsung machines i generally work on ricoh. customer cannot fax at all but only recieve faxes.
    bit of a mystery for me.
  • markyy
    • Feb 2010
    • 3
    Hi,
    did you get a solution with this "document jam" issue?? I have the same issue now.
    Even if you power off and on, display shows "document jam". No piece of paper, dust, aso. at the sensors.
    Thank you in advance
    • ash_572
      • Oct 2008
      • 523
      sorry. i dont remember what happened.
      • JustManuals
        • Jan 2006
        • 9838
        Just Manuals | The Internet's largest selection of manuals | Instant Downloads
        Paul@justmanuals.com
        • markyy
          • Feb 2010
          • 3
          i found the solution by myself
          after cleaning all sensors, checking the circuit board in the feeder with no positive result, i took a closer look at the the cable between the feeder and the machine. i tested the continuity from connector to connector and actually i found 3 broken wires.the position is located between the feeder and the machine, where the cable is most stressed. I opened the cable carefully with a sharp knife and soldered the cables. Works perfect again..
