i have a minolta di200f that has been thrown under my job description. Lucky me my predecessor lost the service manual and I have not yet been able to get my hands on one. It was told to me that while i try to get the approval to get a new imaging unit I could bypass the cf error and still print. The problem i am having is that i do not know the code to get into the service menu to bypass the error. can anyone help?
how to bypass imaging unit error
Tags: addressing, bypass, cf error, developer unit, error, fax, generic toner, grain, imaging, long shot, meter count, pressed, service menu, unit
service mode
for DI250f,350f :
enter in fax mode then press:
19 19 19 19 19 19 19 19 19 19 , * ,panel reset.
If you entered the code correctly start button will begin to wink.
press Utillity- in this menu you will find "service mode" task. -
c-0f32
this is an error for the developer unit, saying that incorrect developer used
or the toner to dev ratio is incorrect. is the customer using OEM or generic toner, because I have had this problem when generic toner is used and the developer/ toner ratio sensing gets thrown offSorry folks, reputation removed by Just Manuals, because he's a sad little wankerComment
service menu
"The problem i am having is that i do not know the code to get into the service menu ..."
try this: utillity-meter count-stop-0-0-stop-0-1Comment
Thanks for the help guys that code Definitely got me in. In the service menu under tech choices and printer though it wont let me adjust the toner grain. I am trying to bypass a grain error while I wait for a new imaging unit. Any suggestions would be greatly appriciated.Comment
Thanks again for all the help with this. I guess you can tell I'm not a regular copier guy but thrown into this. The last code got me to a printer and IR menu where I can change CD and FD but it wont let me change any settings here. Unfortunately my boss expects a working printer nonstop and for me to dig up the manual from thin air. Open to any help that can be provided this model is old enough its hard to find help.Comment
you can leave out the "stop start" at the end of that last post. the "stop 00 stop 01" gets you into the tech rep mode, the "stop start" gets you into a further hidden menu within the tech rep mode.
that being said, im not sure that you will be able to find much help in using these modes. even after clearing the c-0f32 error, it will most likely come back shortly thereafter. I dont know of any way to prevent it from coming back and immediately disabling the copier, besides addressing the actual issue that is throwing the code. I would try running an F8 (in the funtions menu) without the toner bottle in the machine to see if it still comes up with that error. If it does, i would wait for new parts to arrive. There is some chance that you could alter the atdc set-value to the neighborhood of the current-value and get it to work, but its a long shot.
what is the atdc set at now?Comment
