View Full Version : Minolta Di470
digicor
04-28-2009, 09:06 PM
Im having a real problem with a di 470.It will make one copy, try to do two it stops shows a jam at the sep corona, the paper is 1/3rd the way past the sep corona.nothing caught,nothingjammed.I changed the sep corona, the charge corona, i even changed out the e promm.I will not print multiples from the internal paper passage f12 command, it does the same thing.heres the odd part, it WILL print multiple's if you select the paper in landscape and take it off auto for everything,(man peper select)and disconnect the finisher????anybody got any ideas? im out of hair.....LOL:eek:
cobiray
04-28-2009, 10:19 PM
Sounds like a timing issue. Is the registration off on the 2nd (jammed) page? Check the timing and transport clutch.
fixthecopier
04-28-2009, 11:04 PM
I agree. Out of time at the reg roller would make it stop at the transfer.
digicor
04-29-2009, 12:46 PM
thanks guys
ill let you know what give's
