Hi all,
I can only imagine that many of you have run into a client who has a legacy app they refuse to surrender. In my case, I have a client who wants to print from an ancient DOS application to her bizhub 200. We've set it up with the parallel port addition (as the program can only print to LPT1) and a generic HP laserjet 4 driver on the driver side.
The problem I'm encountering is extremely slow response time for prints. She'll send a print and it can take anywhere up to 10 minutes for the copier to print. A couple things I've noticed - occasionally, everything will behave perfectly - she'll send a print and seconds later it will pop out of the machine. Secondly, when the machine is taking a very long time the memory usage meter in the bottom right hand corner of the LCD panel indicated 99% and has an icon that looks like a small box with an exclamation mark.
Has anyone come up with a solution to a similar problem? Many thanks in advance,
-David
-David
