View Full Version : Macintosh Save in User Box C203
Wasfil
05-01-2009, 05:03 AM
Please.
Spec : - Mac OS. 10.5
- Driver C 203 V.5.0.1
How to set about Print with Output Methode : Save in User Box, Secure print in Mac Os 10.5 ?
Im did read and try from Manual book, but still can't. The problem is, menu User Box canot display so im canot input file name and user box number.
give me advice:rolleyes:
pepper38_cnd
05-03-2009, 01:21 PM
If you are not seeing all the options available to the printer it is usually because the printer driver is not being pulled from the proper location. go to the printers and choose the printer where it says driver choose other and navigate to the HDD, Library, printers, and so on, pick your driver from the last directory. Then make sure all your options are set including hard drive. You should now have your secure print or user box available.
Good Luck
Wasfil
05-04-2009, 07:33 AM
Im finished atrouble, i'm download and installed the new version of Driver (V.5.2.7). Thanks for all
