View Full Version : firmware konica 7165
roniirawan
05-01-2009, 03:08 PM
hi...
i need firmware for konica 7165
can anybody help me..
thanks
roni.irawan@gmail.com
DallasTech
05-01-2009, 03:43 PM
hi...
thanks
It's on the SSD page, which firmware do you need? I might be able to email it to you.
carneage
11-17-2009, 05:12 AM
hi there i also need the firmware and any software that goes into the konica 7165 as both of the hard drives on my konica have crashed, if you could email me or Pm me that would be great
carneage@hotmail.com
thanks
carneage
pepper38_cnd
11-17-2009, 01:40 PM
The main body HDD contains no software, the IP-511A HDD must have the system code preloaded on it before installing in the IP this can be done with a ghost image.
roniirawan
11-20-2009, 10:44 AM
hi dallastech
i need firmware for pi 6500e / ip 511 for printer controller because my printer controller can't ready but on the screen appears system booting please wait....
thanks
pepper38_cnd
11-20-2009, 12:14 PM
Have you tried the Restore feature? If the HDD is ok but the System code is corrupt the Restore will reinstall the Original system code of the IP-511.
carneage
11-23-2009, 12:06 AM
the copier has taken a hit in transport and has killed its hard drive. also on bootup it heats up the fuser and hangs in the screen booting please wait a while.... and then nothing
carneage
05-29-2010, 06:44 AM
where could i get hold of a Ghost or any software for the ip511??
totoket99
07-15-2010, 05:30 PM
I have the Ghost Images for Both a 6Gig and 20Gig drive.
However, you need to make sure that your Nic firmware is above 6.30.
carneage
07-16-2010, 01:12 AM
i have 6.28d where would i get the latest update... also how can i up the font list in this IP-511??
totoket99
07-16-2010, 01:19 PM
Are you able to get a configuration and Nic Page printed? If so send them to me. I have all the nic and H/D firmware available.
DESCRIPTION: Unit will not initialize after upgrading the system code of the IP511. SOLUTION ID: 130743
SOLUTION: CAUSE: The IP511 NIC firmware should be upgraded before the IP511 system code.
SOLUTION: To clear the error, it is recommended to temporarily downgrade the IP511 system
code to the previous version. Update the NIC to the desired level and then update the IP511
system code.
carneage
07-19-2010, 12:19 AM
i have a print out every time the printer starts up ... is that the one if so tell me a email add and i will forward
