fuser temperature abnormality. Temp is too high I think. Your one ways are probably shot, cause that code sometimes happens after you get consecutive jams at the fuser.
Hi. I have the same code and yes, the machine has four consecutive jams in the fuser. I'm having this jams only with bond paper media 75gm. In heavier stock (80gm - 300gm) I don't have any jam. Three questions:
1. What I need to do to fix the machine?
2. What would be causing only bond paper get jammed?
3. What do you mean with "Your one ways are probably shot"?
