View Full Version : 7085 finisher problem
smiley
05-02-2009, 03:52 AM
hi guys i have 7085 with 4m on counter but still work great.then i try to install 7075 finisher i thought they are same.when i attach it it doesn't work or even initialize i took another finisher but still dont work.any suggestion i need help please.
Luther
05-02-2009, 05:16 AM
The 7085 uses th FS-111 and FS 211, THE 7075 USES THE FS 108 AND 108B
smiley
05-02-2009, 05:30 AM
thanks for the quick response luther.i still have a problem my adf didn't read 8.5x11 it read as A4 how can i make it read the 8.5x11 as 8.5x11 not a4.thanks:)
Luther
05-02-2009, 01:00 PM
Send me your email address and i will send you the adj.
smiley
05-03-2009, 10:12 AM
hi luther this is my email neil_lcm@yahoo.com thanks.:D
Luther
05-03-2009, 01:15 PM
Smiley i sent the adj section of the manual, it is page 69 (edh size adjustment) good luck
smiley
05-04-2009, 08:48 AM
thanks luther i will try it thank you soo much.:)
BUSHWACKER
05-04-2009, 12:58 PM
Hi Guys, have a problem that the paper/board is jamming as it hits the fuser unit.
Have checked the locating gear at rear of machine seems ok.
Have removed back panel and checked that everything is turning, all
seems ok.
When machine is switched off and the fusing unit is manually turned everything seems to be locating properly.
Any Ideas
Sorry for posting query here but i cannot find where to enter new postings
Help in that regard would also help
thanx
Regards
Bushwacker
Durban:confused:
