hi guys i try to install twain driver for konica minolta then when i try to use it from adobe photoshop i always say check box# and pasword. now im wondring where can i select the box #.any help will appricited.
7145 scanner
Can't remember exactly, but if it's like Bizhub 500, you can't retrieve the documents which are stored from the copy mode, you need to setup a one touch and store it in a box using the scan mode. Box # would be the box number when you created the box. Checking the KMBS site, however, I don't see a TWAIN Scanning Driver or TWAIN Scanning Utility, so possibly it's not a supported feature for this machine? Are you using a HDD Twain Driver from another model?Comment
I don't recall exactly, but you do need the zeros like "0001" or "00001" for box number 1. On the copier you select scan to box or HDD and then enter the box number to save the scan to. You use scantrip or if they have a twain driver and enter the box number and password you used on the copier. We usually use "1" and "1" to make it simple, but you do need the zero's either on the copier or on the software, I forget where. I think you see them on the copier, and put whatever is shows on the computer.
Hope this helps.Comment
Hope this helps.
thanks again.there is no glory without sacrificeComment
