View Full Version : bizhub 3510f
Vesigoth
05-05-2009, 03:58 PM
hey guys. what's a c-133A on a 3510f thanks
copytechman
05-05-2009, 04:46 PM
From da book:
C133A
Main Unit G/A Communication
Failure
• Communications with the gate array for expansion
I/O (the IC mounted on the Master Board) fail.
C133A
• Communications with the gate array for expansion I/O (the IC mounted
• The Light Emitting Diode on the PWB-A Board does not flash.
1 Turn the copier off, then on again. — — —
2
Check each control board and the
Master Board for proper connection,
and correct as necessary.
3
Replace the Master Board if necessary.
Good Luck!
time2fly
05-05-2009, 04:47 PM
(30) C133A: Main Unit G/A Communication Failure
<Detection Timing>
Action
Trouble
Code
Description
C133A
Relevant Electrical Components
Master Board (PWB-A)
Step Operations
Ref.
Page
WIRING DIAGRAM
Control signal
Location
(Electrical
Components)
2
3
Vesigoth
05-05-2009, 06:11 PM
thank you everyone
