View Full Version : calibration
noklasony
05-13-2009, 01:13 PM
hi guys
machine 6500 and fiery 305
i want calibrate my machine with EFI 1000 i got this device from my friend can any one help me how to use this device which software require . i have only EFi1000
Albonline
05-13-2009, 03:18 PM
you need the eyeone driver and command workstation. loginto ic 305 as admin, server tab ,manage color, expert, print chart, 34 sorted, scan with es1000, compairison printout to confirm quality, then accept settings.
noklasony
05-13-2009, 06:43 PM
dear thanks for reply
can u send me i-one driver because i dont have driver cd thanks again for ur help.
Specilist KVN
05-13-2009, 06:49 PM
The driver is actually stored on the ES-1000 itself.
If this does not work, then go to the Greytag Macbeth website and look for the I-1 Pro device.
It used to be spelled I-ONE.
Load it to a disc and point to that when installing, but it should see the driver on the device.
You calibrate your Fiery with Colourwise Pro Tools and NOT Command Workstation.... Select your device from the list and follow the instructions.
Print the 34 randomized patches on an 11x17 and use this to calibrate.
BCR8TIVE
05-13-2009, 09:42 PM
Go to the web knowledge base and look up document number TAUS0657985EN04 (http://onyxweb.mykonicaminolta.com/NewKB/KBDocument.aspx?id=TAUS0657985EN04&ptid=). It's Troubleshooting Guide 2.0. It's step by step instructions on calabrating, as well as alot of other information.
noklasony
05-15-2009, 05:51 AM
hi guys
thanks for your replys
but i could not find driver can any one send this es 1000 driver or link where i can download directly.
random
05-15-2009, 10:30 PM
You shouldn't need any driver to run this once you have installed command workstation (http://www.efi.com/cws5/)it should be just plugin and work.
noklasony
05-16-2009, 01:01 PM
hi random thanks dear YOU ARE THE MAN i done this successfuly there is no need driver its plug n play thanks for ur great responce
