fishleg
05-14-2009, 05:03 PM
Hi,
We recently started a rebuild in the workshop working machine was a bit pitted inside but it was working. Obviously usual parts replaced dev drum corona's etc full service boards where not touched but when finished after around 50-60 copies the machine comes up with E56-1. It was a customers machine so we know it was working with no previous history noted.
E56-1 is described as some sort of communication error between the control and driver board so what we have done so far....
Machine firmware was v10 both image and system controller. so..
1. Flashed original boards with v11 image and controller same problem
2. replaced both boards and flashed v11 firmware same problem
3. Tried without df connected same issue
4. changed nvram factory reset
We where getting a couple of E89-1 and E89-2 codes randomly after flashing boards but the main issue seems to be this E56-1 code. Everyone in the workshop is completely bamboozled since it happens after 50-60 copies its a hard one to put a finger on.
It is strange though if you try to run the dev the code almost immediately appears. Can this code be caused by the units some how ?
Does anyone have any ideas as to what try next ?
Cheers,
Mike
Cheers,
Mike
