View Full Version : C500 with a 32-01 code
dl4tech
05-21-2009, 04:19 PM
What could be causing this code on a C500? 32-01
wizpar
05-22-2009, 12:51 AM
according to service manual
When the fixing cooling fan /1
and /2 (M10, M36, M37) were
ON, abnormality detection signal
of either of them was continuously
detected for the
specified time.
Printer control board (PRCB)
Fixing cooling fan /1 (M10)
Fixing cooling fan /2 (M37)
Fixing cooling fan /3 (M36)
laserman06
05-22-2009, 11:33 AM
Is it a jam code or a service code?
If it is a jam code, check the 3 one-way gears in the fuser gear box.
If it is a service code, see above post, by wizpar.
dl4tech
05-22-2009, 07:17 PM
Service code. Ordered the above motors, turned out to be a sometimes slow turning M36, the second motor behind the first one. IO check 42-03 would show the motor turning once in a while (thus the code). Replaced and tested with the finisher and the covers off for 45 minutes. So far so good. :)
