View Full Version : Bizhub C351 Transfer belt fuse?
X Xerox
06-02-2009, 10:41 PM
I have heard that you can reuse a transfer belt if you replace a fuse. Can someone please tell me where the fuse is and where I can get a new one.
pepper38_cnd
06-03-2009, 01:50 AM
The fuse OEM is 62Ma but 63Ma is the most readily available ( and for some strange reason much cheaper ) and will work fine. I can sell you the fuse but it is a standard mini glass fuse available from any electronic store. the fuse is located right where the 2 silver contacts for the belt are located. If this is not enough info to get you there send me an email info@iureset.com and i will send you detailed instructions.
X Xerox
06-03-2009, 05:16 PM
Thenks for your help so far but the link to your email didn't work on my server. If you could email me the instructions for replacing the fuse on the transfer belt module to dennis@gdpandg.com that would be great. If anyone else could email me some instruction that would be helpful also. Thanks
OutlawTorn
06-04-2009, 09:56 AM
I wouldn't mind these instructions either!
email craig@shetlandoffice.demon.co.uk
8050
06-04-2009, 12:35 PM
Very easy to replace fuse. You don't even have to totally remove the transfer belt unit! Pull out transfer belt partway. On the front side you will notice one screw on the top of the cleaning unit for a small cover. The fuse is underneath it.
edmund
07-09-2009, 09:55 AM
please note MUST BE 80 mAmps!!!!!!
edmund
07-09-2009, 09:57 AM
THERE ARE FUSES FOR THE FUSER ASWELL
look inside the harness of the fuser unit there a green fuse(PICO fuse) 16th of an amp!!!!! PLEASE NOTE !!!!!!
