View Full Version : 7155/65 dc power supply fan
ebm
06-09-2009, 03:04 AM
Anyone know where to get replacement cooling fan for the DC power supply? It is a damn shame to have to pay hundreds of dollars for a new power supply when the only problem is the fan. Tried looking at other konica models but cannot find any with 24vdc, .012 amp cooling fan.
TheOwl
06-09-2009, 03:26 AM
The best bet is to go to an electronics store with the fan and give some one at the store a look at the fan. Most fans can be bought locally.
Just look for the following:
1. Voltage ratings on the fan
2. Current (AMPs)
3. Connector
4. Fan Size
5. Blade pitch
The first 4 points are cruicial, but point 5 should be noted as the factory fans are designed to move so much air. Moving less air could cause overheating issues and moving too much air could cause excessive current drain from the circuit.
ebm
06-09-2009, 03:34 AM
2. Current (AMPs)
3. Connector
4. Fan Size
5. Blade pitch
We tried checking a couple local elec. supply stores. No luck. This is not a very common fan. I was hoping another Konica tech might know if this fan was used in another Konica model.
Thanks for replying.
TheOwl
06-09-2009, 03:39 AM
Bummer about the electronics shops not having any. Other than that, I can't really help sorry.
