View Full Version : km 3040 c-9000
toner89
06-11-2009, 05:37 AM
hello this machine send me this code i check the voltages its ok ,but when the customer lift the dp to make copies direct on the glass apears c9000 if its the board on dp i have the manual parts but doesnt have the dp part number any help.
i run sumulation 906 and still same problem
Lbcoaster
12-17-2009, 06:53 PM
Were you able to find a solution for this problem? I am having the same problem...
Steve
@ Lbcoaster@aol.com
n25an
12-21-2009, 04:49 PM
Disconnect the dp and test... if you get the error its the dp...
Lbcoaster
12-21-2009, 05:08 PM
If you disconnect the DP(Doc Feeder?) shouldn't the problem go away if its the DP?
thanks for the help, the feeling is there's a short some place.... just a thought I'm still got my problem
n25an
12-22-2009, 06:08 AM
if the problem goes away... then its the document processor...
you can either replace the document processor board and/or the harness... I would do both...
tech07
02-06-2012, 01:20 AM
Replace the cable that goes from the copier to the DP..I have done this...There is a technical bulliten
blackcat4866
02-06-2012, 01:43 AM
You do realize that this thread is three years old? I certainly hope it's been resolved in some way. =^..^=
Lbcoaster
02-06-2012, 03:11 PM
Yes, had to replace the main logic pcb....
Lbcoaster
01-09-2014, 01:04 AM
you're welcome, never know when someone may need the info....
