View Full Version : EP 1085 Outputs blank copies
nmurugesan
06-12-2009, 05:40 PM
All of sudden KonicaMinolta EP1085 black and white copier started producting blank copies. The copier was working fine. There was thunder storm over night. Anything needs to be reset? or any idias to diagnose and correct this problem?
poz31
06-12-2009, 06:17 PM
Since ison the same idea of that 1080s family.......it coul be the high voltage unit ...check basics as a false conection between the springs and the therminals check your corona units.. if something goes bad on one of teh units it wiil create blank copies
cobiray
06-12-2009, 06:18 PM
Stop the copy process with the paper under the drum. Remove the drum unit and inspect it for image on the drum. If the image is present on the drum there is an issue with the transfer section. If there is no image on the drum, there is likely an issue with the HV unit.
Check the Transfer Corona Wire.
If the wire was broken, re-strung the wire. If not, use a hair dryer
to expel the moisture inside the machine.
minimerlin
06-12-2009, 08:30 PM
You can normally see the charge corona glowing purple if you jig the door and watch it while running drum dehumidifier or even during a copy run. Also there is a high pitch whine when hv unit is operating.
xcopytech
06-12-2009, 10:51 PM
Think that you have to call service tech to fix your copier.
This guy is end user and even this is old machine, think that he have to give his local tech chance to earn some money.
:(:(:(:confused:
