View Full Version : samsung scx6322
This machine have to change the drum at 20.000 print's. Mostly of the drum's are in very good conditions at 20.000 copies. Someone knows how to make a reset to the drum's. In the manual they say how make this, but in the machine don't appear that option.
Thanks.
northerntech
06-16-2009, 08:31 PM
there is a chip like device in the drum unit and in the toner unit... if you can source the chips you can reuse the drum... and if you find chips and toner you can refill the toner unit
tseto
06-29-2009, 11:50 PM
Thanks.
The end of the drum has a 63 ma fuse attached. the fuse resets the drum counter and itself gets blown. You can go to your electronic store and get a 50 to 60 ma fast blow fuse and replace the blown one. You can buy replacement drums also if needed be.
