Bizhub PRO C6500 Banner Printing
  • drodas78
    • Jun 2008
    • 91
    Hi. Anybody knows if it's possible to print banners in the C6500?
    Regards.
  • llla
    • Jun 2009
    • 8
    Regards.
    Hi.
    change dip-sw 10-0:1 and 10-1:1, remember to set it back for normal printing.
    • drodas78
      • Jun 2008
      • 91
      Thank you for your answer. I found this file:
      But I have the FS-607 finisher installed. Can I print the banner with the finisher or I need to remove it first?
      • llla
        • Jun 2009
        • 8
        Regards.
        You need to remove the finisher, the pdf file tell you all. Only 6500smart and IC408
        • blago_vd
          • 38
          You can print banner with IC-304 Creo , but only 600mm.
          • kmcopier
            PSP
            • Oct 2008
            • 183
            no there is an patch for 1200mm
            • baralex
              • May 2010
              • 3
              that the patch ?
