View Full Version : Konica Minolta Bizhub C353
brasilmichaele
06-22-2009, 05:23 PM
occasionaly the machine looses connectivity with the network. Turn it off and on and it comes on and works fine. help if any info.
I think it is the MFP Board. I had this twice. You can try a firmware update but i don't know if it helps.
TheOwl
06-23-2009, 03:00 AM
A few things to look at before changing the MFP board.
1. Make sure that SNMP Status Enabled is turned off in the printer port.
2. Make sure that the network cable isn't coiled up around oe near a power cable.
3. Unplug the network cable when it has dropped off the network and ping the IP address to make sure there isn't a duplicate IP address.
4. Plug the machine into another network outlet to make sure the cabling in the wall is fine.
5. Firmware upgrade.
6. MFP board.
abilashvk
06-24-2009, 03:05 AM
hi,
Try what the owl says and also PWB-MFP got NV-RAM on it,which stores the static IP address etc., There is an nv-ram,NIC resetting firmware flashing which can address such issues.Interchange NV-RAM from a compatible model and confirm (also change IP address.SUB NET mask etc,.of that nv-ram).You can also detach the batter from Nv-ram,keep it for some time to get the NON VOLATILE data errassed from it,do a firmware upgrade and go.......
I don't think, that this is a good idea because then he will lose all the machine datas and he will probably hat to do with a "licence error". Beside that he will have to use the NVRAM flash card to flash the NVRAM for his machine (C353 in this case).
StormyKnight
06-25-2009, 12:23 AM
Another thing to try is to force the network to 100Mb OR 10Mb & even try the full duplex or half. If left on Auto Negotiate, the network switch (or hub) that the machine is connected to may not work correctly.....
abilashvk
06-25-2009, 02:26 AM
Hi DCPS,
I had previous experience in C250,252,352 etc,. regarding NV-RAM data erasing issue.To do that ,we must have with us both the firmwares (ie. nv-ram&machine) or atleast machine FW.After that machine will ask for printer serielno,.(,most probably language japanese-change marketing area in SYST1 of ser.mode - KM logo will be replaced by an outer space- change HEX 10 to 00 in SW Setting & fix) DO A FW UPGRADE start all necessery installation procedure.Only risk I observed is that meter reading might change to millions and more,which we have to inform customer to follow mechanical counter.May be by this way he can save a few bucks of a new NV-RAM.
But,do this by taking permission of THE CUSTOMER and inform the pros&cons. After all its his machine and he's just allowing us to rectify his trouble :)
Dip switch 10 should change to 02 and not to 00. Otherwise you want have a Bizhub but a Generic machine.
abilashvk
06-26-2009, 02:12 AM
presently Iam changing hex 10 to 00 and every thing including KM logo goes right, any way I will give a go t0 02 and try
pepper38_cnd
06-27-2009, 11:27 PM
You don't by any chance have the Bio-Metric (finger reader) attached to this machine do you? We have had no luck with this as any machine we have installed this on drops off the network continuously after going into low power or sleep mode. We gave up and just removed the Bio-Metric and stopped selling them.
pdcopiers
06-17-2014, 05:43 AM
Hellow, today I had another problem with a Bizhub C353, It was working perfect but today the client called me because the machine stop printing. I went there and I noticed that the lights on the ethernet port was blinking every 2 seconds. The machine don't loose the ip, but when i tried pinging it, is not response. I don't know was going on, I haven't see this problem before bizhub c353 series. Any suggestion? please
rrrohan
06-17-2014, 06:27 AM
what if you plug into your laptop with cross over cable?
maybe set the IP manually
pdcopiers
06-17-2014, 04:36 PM
Thank you for your response. I haven't try to plug into a laptop, I can try today. I set the IP manually and the machine keep the IP but is not communicated to the network. But if I left it automatically, it change number but the Gateway change to zeros...
copyplus
09-06-2014, 01:08 AM
Can I use toner from TN 413/613 into Toner cartridge TN611? thanks
