View Full Version : Ikon CPP 650 / Bizhub C6500
Dedotch
06-22-2009, 09:35 PM
Does anyone have or know of a Friery that will run this machine. It is an Ikon CPP 650. I don't know if a Bizhub will work? Need a finisher too.
Thanks, Scott
jma676
06-30-2009, 10:31 PM
Fiery S450 or IC-303 Check This Place: http://dk.ikon.com/support/downloads/products/Brochurecpp650.pdf
If you're an IKON location, you can get a Creo for it as well.
The Creo would need to be version 2.x to support the CPP650; 1.x won't work.
You also have the option of the X3eTY2 "piggyback" controller, although it's not quite as powerful as the other RIPs.
jma676
07-01-2009, 12:17 AM
I`m not belong Ikon, Sorry I don`t have access to Controller Software.
Fiery X3e TY2 is IC-408 Embeded Versions Controler, You Need Firmaware (G00-30) Actualizacion for use this Controller in 1.1 Version. This case for a Bizhub Pro C6500.
