View Full Version : Bizhub C250 ADF not being recognised
Tactiveboy
06-29-2009, 11:50 PM
I have a C250 bizhub which won't recognise it has an adf fitted. When you check the firmware it shows no adf firmware installed. I have flashed the machine firmware and tried a different adf with no luck.
jprecht
06-30-2009, 01:48 AM
Hi, was this bx wking b4? if it was wking with the orig adf and quit than you have a conn/bd issue. obviously there are sev ":test pts" you need 2 ck. more info and get out your meter!! when you changed tops was same adf? if so eliminated pt of trouble. suggest you wk bkward on this one.
albasoul06
06-30-2009, 04:37 AM
maybe there is a fuse on the power board ... you know, just for the adf board ? like the fuse for the fuser unit, power unit... same thing
jprecht
06-30-2009, 04:48 AM
we need more info on this one , but still suggest you wk it bkwards!!
jp
Tactiveboy
07-16-2009, 09:06 PM
Thanks for the replies. feel a bit of a div fault was a cracked loom which had blown a fuse on the power board.
