View Full Version : help b421 jamming at registration
tarzak911
06-30-2009, 08:28 AM
cassing the paper 1 and 2 are ok but the lct it is creasing and making waves....in paper.
changed registration unit...:):):)
copytechman
06-30-2009, 11:05 AM
Try washing the lower relay clutch, thats the one just below the reg unit on the vertical transport, i believe it comes out with the tray 1 feed roller unit.. Had some good success with that..
Or.. b4 doing that try adjusting the printer resist loop in service mode for the tray in question.
Regards.
A.
copytechman
06-30-2009, 11:06 AM
Regards.
A.
Edit: by washing I mean with 99% isopropyl alcohol. And then drying it out..
mo0651
06-30-2009, 03:06 PM
Did you replace both clutches in the registration unit? I've never seemed to get only one to fix the problem.:cool:
copytechman
06-30-2009, 03:49 PM
I have also done that in the past but found it wasn't either of em, it was the relay clutch that fed the reg unit not letting go (sticking) causing too much buckle etc etc
Regards!
A.
tarzak911
07-01-2009, 08:17 AM
thanks guys found da problem... tried what u said....problem was black door pawl cracked ...took some time to find this1....
tarzak911
07-01-2009, 08:20 AM
check for cracaked door pawl not closing proerly... thx 4 your help.
copytechman
07-01-2009, 11:53 AM
Cool will do that as well...
Regards!
A.
avanza
07-17-2009, 08:26 PM
it is very common for bizhub 420/500 to have paper jam around the registration units. The cause of this is actually the adu clutches is 'slip' by the greese. just clean it up with alcohol or replace.
