Konica Minolta Bizhub C451 Password
  • kldcopynprint
    • May 2025
    I don't have anyway to contact my original tech who setup my machine. I am trying to network my copier, but I need to be able to get in my admin. setup on the copier. It needs a password and I don't know what it is. I tried to use Firey.1, but it didn't work. Is there any other way I recover the password or reset it?
  • cboucher
    • May 2025
    Passwords to try (case sensitive):
    Fiery.1
    01234567
    12345678
    00000000
    Good luck...
    • jprecht
      • Dec 2008
      • 104
      admin nightmare
      Hi, usually your default is all 0's have info on k/m 2230 when you get in you have to fight 2 get "copytrack" to off. i'm not sure but i think if you "re-initialize" from the svc pcb (short two" in " pins and while holding both service buttons down, turn the bx on hold everything for 10 sec or so you should get a "re-init cmplete" message. has been awhile but this wks for the older k/m colors. let us know what you found pls.
      jp
      IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
      THAN TO SPEAK AND REMOVE ALL DOUBT
      • Si@danwood
        • Mar 2008
        • 154
        12345678 is the default password for admin settings on the copier!If it has changed then you will need a tech to call and reset it for you!...Si
