View Full Version : KM-7530
hptech09
07-05-2009, 09:41 PM
Purchased a KM-7530 off craigslist. Is there a default admin password for this model that I can try? If not, is there a factory reset procedure I can use?
kyoceradude
07-06-2009, 11:57 AM
It depends on what you are trying to access. Is the machine calling for an account code to make copies? If you received a manual with the machine the info you need is in section 7 Copy Management. If you did not, you can go to a website Kyocera Color Laser Printer Copier Scanner Fax MFP Products (http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=10497&rid=11141) and download it.
Craigdumass
07-06-2009, 02:40 PM
usually 6482 is the one to get into machine settings.
kyoceradude
07-06-2009, 03:27 PM
Craigdumass:
Now why would you want to post the tech code. Just give them the default for the machine like "7500" for the KM-7530. Plus you don't even know what they wanted the code for. Admin code or Job accounting. For pete's sake stop giving out tech codes unless you know for sure it's a tech. DAMN!! If you read my post I gave the end user a link to get the Op manual to access the infor they needed, that is available to anyone.
Craigdumass
07-06-2009, 04:37 PM
Sorry I did not know I was giving out our national secrets.
