View Full Version : Firmware problem C500
alexg
07-06-2009, 07:12 AM
Hello, I have a problem with Hp 9850mfp, which is KonicaMinolta Bizhub Pro C 500/8050. I've loaded firmware provided by KonicaMinolta and machine shows SC 81-01 that means rom version doesn't correspond to the model. Anybody could send me Hp original firmware.
Thank you.
Alexsky
09-24-2009, 10:26 AM
Hello ,, Can you send me the firmware C500 pro ,,, because I have this problem sc-80-01 and I donīt have this firmware
Thankīs
john greece
10-12-2009, 09:56 PM
Thank you.
I have the IKON PRO 500C (KONICA MINOLTA BIZHUB C500) I've loaded firmware provided by HP 9850MFP and machine shows SC 81-01 and I dont know what to do. I have hp9850mfp firmware and i can send them to you if you have konica minolta firmware bizhub pro c500/8050 thanks.
john greece
10-13-2009, 09:47 PM
Thank you.
i CAN SEND YOU THE LATEST FIRMWARE HP 9850MFP AND ISW.
CAN I HAVE THE FIRMWARE AND ISW FOR KONICA MINOLTA BIZHUB PRO C500?
mongol1255
11-09-2009, 12:05 PM
my copier c500 fault code 56-11
can you help me ??
john greece
11-09-2009, 12:37 PM
can you help me ??
THE MANUAL SAYS
''Operation board /1 (OB1)''
I BELIEVE YOU NEED TO CHECK THE FIRMWARE
RRodgers
11-09-2009, 03:26 PM
I wonder why you guys would even "TRY" to flash the firmware on these boxes?!?!?
otomatic
03-14-2014, 05:16 PM
we have just got the sc 81-01 on our machine
it was jamming then kicked one the fuser temp codes and I reset that then I got 81-01
is that code a firmware issue and if so where on earth do I find it?
Tonerjockey.com
03-18-2014, 01:07 AM
Thank you.
There's a bulletin that shows this...not sure it's helpful as it seems to easy.
CAUSE: Dipswitch 4-0 is set to 0 (OFF) in the 25 mode.
SOLUTION: Set dipswitch 4-0 to 1 (ON) in 25 mode.
Nate
hugohug
07-18-2016, 12:21 PM
Thankīs
We are very badly need of firm ware for konica minolta bizz hub c 500 mfp printer .please let me know the availability.we have got two printers giving 80-01 error
hugohug
07-18-2016, 12:26 PM
Sir...we do not know the procedure for flasing the firm ware on these boxes.please give the procedures to enable me to try to flash on these boxes.we have got 2 now od c 500 mfp printers with 80-010errors
RRodgers
07-18-2016, 01:23 PM
I guess the next question is how bad do you need them?
hugohug
07-22-2016, 08:15 PM
My both c 500 printers are down for want of c 500 firm ware.please let me know where I all get them and how much we have to pay to get them
