View Full Version : Fuser temperature at Minolta Bizhub C500 Pro
robizhub
07-07-2009, 06:06 AM
Please tell me how to lower the temperature in the fuser of Minolta Bizhub C500 Pro.
Thanks!:)
random
07-07-2009, 06:40 AM
use a lighter paper weight
robizhub
07-07-2009, 07:00 AM
I use 90g coated paper ( and the broblem aperar at the second side of the print - exfoliate paper) and if I lower the weight I must use normal paper.
so I will try.
Thanks:D
KM Dude
07-09-2009, 05:40 PM
Fuser temp is set using 25 mode softswitches, it should be listed in the service manual.
lucky13
07-09-2009, 09:49 PM
is your paper blistering (bubbling) then you need to use good quality coated laser paper made for copiers .press paper will not work
mrwho
07-09-2009, 10:28 PM
This is one of the big problems the 8050/C500 have that was solved with the arrival of the C6500. More than one customer I used to visit swapped their 8050/C500 for a C6500 and are still happily using them.
robizhub
07-10-2009, 06:41 AM
Problem solved!
Tahnks to KM Dude :"Fuser temp is set using 25 mode softswitches, it should be listed in the service manual." I have dowgrade the temperature with 10 degree. And all is ok!
Albert
05-01-2011, 04:46 PM
Problem solved!
I have the same problem but i dont know what soft-switches to adjust. Can you tell me please i would like to lower my fuser temperature to 10 degrees. Thank you
RRodgers
05-01-2011, 07:06 PM
As stated above, its in the manual.
Albert
05-02-2011, 01:53 AM
In what page number would i find it? thnks
mrwho
05-02-2011, 08:15 AM
Page 1-17 (page 49 on my PDF). Check item *13.
Albert
05-09-2011, 09:25 AM
Thank you it fixed my problem by lowering the teperature by 10 degrees
