View Full Version : di2510f PC fax
can show me hot to setting the PC fax for Di 2510f thanks .urgent !!!!
help ! teach me how to setting for PC fax .
rasman67
07-08-2009, 03:33 PM
first you will need to have the SU-3 installed in the copier, next you will need the software for network scanning. You will also need to set Gateway TX to "YES" . It's under Admin 2, Network, Scanner Settings.
After software is installedyou will need to do the setup.
thanks for reply. it work ... :D
