View Full Version : Konica Minolta C250
Data light flashes, you can ping it but does not print. I have done a nic & nvram recovery, and it is on v3.05 firmware. Customer is chargable and very nice so i do not want to throw boards at it if i can help it.
All help appreciated.
copytechman
07-10-2009, 11:33 AM
Did u actually reflash the machine firmware?
Regards!
A.
Regards!
A.
Yep.
mrwho
07-10-2009, 11:44 AM
DESCRIPTION: Unable to print. The data light blinks but no document prints (including a test page). SOLUTION ID: 238248
SOLUTION: CAUSE: Incorrect Image Controller setting.
SOLUTION: Set the proper Image Controller setting. To set the Image Controller mode, perform
the following:
1. Enter Service mode.
2. Select System 2.
3. Select Image Controller setting.
4. Select Controller 0.
5. Select End/Exit to exit the service mode.
copytechman
K, no codes in machine (account tracking or anything?)
A.
copytechman
07-10-2009, 11:47 AM
Heh Beaten! What mrwho said!
Does it show in the log/job history?
Regards!
A.
the following:
2. Select System 2.
Ok, it was set on Controller 3, so now i have selected controller 0 and entered that..............................now the networksettings button has disapeard.............
mrwho
07-10-2009, 12:18 PM
Wait a couple of minutes... it's probably reinitializing...
Yea i was just being an arse machine is now up and running thanks dude, i'll add to your rep.
Although the 20ish year old chick here is so happy now she says if you can pop over she will take you out for a few drinks:o:D
I think the taxi might be a bit pricy!!!!!!!!!!!!!
mrwho
07-10-2009, 12:32 PM
Thanks. Tell her I'd like to, but I'm a little bit far away - although if I ever go to the UK (about 1000miles), I'll call you to charge that drink! :)
Glad it worked. Cheers!
